Any oil gurus out there?
Started by deedub, September 27, 2018, 02:16:36 PM
deedub
For my Passat R36, I saw that Castrol Edge 5w-30 is the recommended oil. I happened to see some on sale so I ordered it without thinking too much about whether there are different variants. I noticed that the oil that arrived is Edge 5w-30 SN. Curious about what the 'SN' part means, I investigated to find that the VW 504 approved "Edge 5w-30" is either ACEA C3 or "Edge 5w-30 A3/B4" which is ACEA A3/B4 for VW 502 (and is API SF).
Now the oil that arrived is ACEA A5/B5. My understanding is that this is a long life oil so probably in line with VW 504, but it is also low-viscosity. Whether that is OK in VW engines, I am really not sure ...
I can return it and exchange for "Edge 5w-40 SN" which is ACEA A3/B4 and VW 502 approved. I would rather run an approved (or equivalent) 5w-30 though. Any thoughts?
johnp
I think the ACEA C xx is for diesel oil rating?
Gordo
5W-30 is 5W-30 - the viscosity is the same, but there may be a different additive pack used.
TBH, with regular oil and filter changes I wouldn't worry about it, especially as normally the higher the number (or letter) the later and higher the oil standard.
dummer
Naekyr
the VW approved stuff is usually "long life" - but tbh I wouldn't bother non long life is perfectly fine, I just change oil 6 monthly anyway
deedub
Thank you for the comments guys. I did some more research...
Quote from: johnp on September 27, 2018, 07:13:37 PM
You're probably correct. One of the Castrol 502 approved oils is C3 rated, so maybe it's a Castrol diesel oil that happens to meet the 502 spec.
Quote from: Gordo on September 27, 2018, 10:05:20 PM
This is incorrect. SAE 5w30 does not indicate specifications such as the HTHS. So, ACEA A5/B5 oils, even with the same SAE viscosity, are designed for reduced fuel consumption in engines that can handle a low High Temperature High Shear viscosity.
Therefore, engines designed around the A3/B4 specification could be subjected to accelerated wear. In this case, higher numbers indicate a more modern specification but certainly not a higher standard. A5/B5 replaces A1/B1 I believe, but is not from the same series as A3/B4.
I couldn't find any reference to whether the VW 502 or 504 spec mandates a higher HSTS than the A5/B5 specification allows. I got in touch with Castrol who told me strictly not to use their A5/B5 oil in any VW motor that is not designed around the VW 508 or 509 spec, which the R36's BWS is not, apparently. So I returned the oil and got the Edge 5w-40 which meets A3/B4.
Quote from: Naekyr on September 28, 2018, 11:53:45 AM
I'm also not concerned about long life, but I want to make sure the oil I use is going to offer enough viscosity to protect the engine - esp. since the R36 engine runs pretty high oil temperatures.
Gordo
#6
I stand corrected, although the viscosity and additive pack comments were right, the latter is rather more significant than I gave it credit for -
"ACEA A3/B4 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & DI Diesel Engines, but also suitable for applications described under A3/B3.
ACEA A5/B5 Stable, stay-in-grade Engine Oil intended for use at extended Drain Intervals in Passenger Car & Light Duty Van Gasoline & Diesel Engines designed to be capable of using Low Viscosity Oils with HTHS Viscosity of 2.9 to 3.5 mPa*s. These Oils are unsuitable for use in certain Engines - consult vehicle-OEM?s owner?s manual/handbook in case of doubt."
Full article - https://www.oilspecifications.org/acea.php
heylinb4nz
I've been using Penrite Eviro+ 5W30 which has the VW approval rating. Usually pick up for $84 for 5L at Repco when on special.
