MK6 GOLF R START UP NOISE
Started by emilyvward94, January 04, 2019, 11:53:29 AM
emilyvward94
Hello all!
For awhile now i've been dealing with a start up noise on my 2010 MK6 Golf R CDLC. I just need some help with possible causes from everyone if anyone knows what it might be so i can take a look and attempt to fix it!
Seems to be oil pressure related, will only happen when the car is turned off for 10 minutes or more. Doesn't sound metallic. Sort of sounds like a misfire as it travels through the exhaust but can be heard best at the front by the engine. The noise lasts for all of 5 seconds, and the car doesn't drive any different.
Car has done 137,xxxKMS. Timing belt and water pump done at 98,000kms. Have always used Liqui Moly oil serviced every 5,000-10,000kms. DSG service done around the same kms as timing belt. Cam chain and tensioner along with VVT done at 134,xxxKMS. Car very rarely uses oil and doesn't smoke unless hard acceleration.
Link here: https://youtu.be/tXxW_Aq12l8
