Well, not much has been happening since my last update but I've done a few house keeping things. New WOF which required me fixing my tail lights. For some reason or another I wasn't getting power to my back right so at this point in time I just jumpered from the left tail lights. Not ideal but will do for now.
I did however while I was in the area of the tail lights 3D printed myself some new tail light housing clip things. I was 2 short and so decided I would draw some up in fusion360 and print some. I should've changed the way I had them supported when they were printed but its in the boot and I don't have to look at them haha.
The 3D printing continues! I had no centre console air vent flap. As I'm sure you're all aware as cars of this age try to blow are in any direction it tends to go in every direction. Feet, face, windows, just where ever. So having the option just to close off the centre vent even though I was on the demist setting is a bonus.
It doesn't have any sealing foam around the edges like I'm sure the original did but an upgrade and upgrade right haha. Only took me about 3 changes in design to get it to work right as I had nothing to measure off other than the vent itself.
Also made a cigarette light plug to fill in the missing cigarette lighter
As far as mechanical side of things go, today i replaced the rear differential mount as upon heavy acceleration and deceleration I would get a but of drive train clunk. Diff doesn't feel overly worn out with backlash which is a bonus. Getting the mount off without pulling the entire sub frame is a pain in the butt though. Got it out and can see the rubber is cracked and pretty much separated all the way through.
I then proceeded to not take pictures of pressing the original bush out in a 20t press because there was a lot of swearing going on about how much effort it was taking to convince it to move without cracking the actual mount. I replaced the bush with 171199214D which I believe is a gear box mount from a 4 speed diesel VW? Not sure but it pressed straight in. Have read online that you may need to skim the inside of the housing but mine was .3 under the size of the bush so thats light press fit clearance. The bush has an off set hole but the subframe is slotted so it all worked out.
Have also done a compression test on it to get an idea on what the internals are like.
Cylinder 1 - 180PSI
Cylinder 2 - 180PSI
Cylinder 3 - 180PSI
Cylinder 4 - 170PSI
Cylinder 5 - 95PSI Wet - 105PSI
So theres something possibly in the top that has got a bit of a leak some where. Valve seat, seal, who knows. One day I'll pop the top off and get it re done. Have to save those pennies and find the bits first haha.
