Coding so far has been easy, removed the auto trans from the Can installed list and re coded the engine ecu to manual.
Turn the key on and to start, the depress clutch message pops up. Push clutch in and presto engine start.
With the wiring in and seemingly everything works as it should I put the dash back in, I probably didn't really need to pull it but I'm glad I did as its given me way more room to work so in all I feel it was worth the extra hour or two to pull out.
Getting at the pedal and wiring would be a right ball ache with the dash in place.
Dash going back in and making sure all the scrwes go back where they came from, VW has really perfected assembly as they have greatly reduced the amount of fastners needed to bolt these things together.
Console back in with ofcourse the best part, a 6 speed gear stick! Added a new screen and sat nav hard drive so that will require messing around with to get working but now's the best time to install it.
