Author Topic: Mk6 timing chain tensioner  (Read 4751 times)
Offline Jtwo
« on: March 03, 2019, 10:30:07 pm »
Hi there, got a 2010 gti mk6 and got fairly paranoid over the problematic timing chain that it may have. All is good for now but would like to do some preventive maintenance before I go ahead with a tune etc. Could someone recommend me a mechanic who can get this looked at for me and approximately how much this would cost. Thanks in advance appreciate any help provided :)
Offline McDoof
Re: Mk6 timing chain tensioner
« Reply #1 on: March 04, 2019, 10:04:20 am »
Hi, welcome to the forum. Let us know where about you are located and I'm sure we can find you a decent mechanic in the area.
Offline Naekyr
« Reply #2 on: March 04, 2019, 11:59:26 am »
let me know if you get a good deal, I'm keen to get this done too
VW dealer quoted me $1800 which is a bit much for me
I'm in Auckland
« Reply #3 on: March 04, 2019, 01:16:09 pm »
Another one, you are justified in being paranoid. Just doing one now.
1200+ with genuine parts.
Offline Jtwo
« Reply #4 on: March 04, 2019, 01:18:55 pm »
In Auckland but correct me if I'm wrong but wouldn't just the timing chain tensioner replacement be sufficient and not a complete timing chain replacement?
« Reply #5 on: March 04, 2019, 01:21:58 pm »
No, the chain is also prone to stretch and has been re designed. Always replace both.
« Last Edit: March 04, 2019, 03:42:47 pm by 80 Vert »
Offline McDoof
« Reply #6 on: March 04, 2019, 01:47:58 pm »
Is that what you charge for the job? Pretty reasonable considering the alternative.
« Reply #7 on: March 04, 2019, 01:59:03 pm »
Correct, parts and labour
Offline DanZ
« Reply #8 on: March 04, 2019, 02:50:13 pm »
Where are you located 80 Vert
« Reply #9 on: March 04, 2019, 03:41:47 pm »
In Henderson West Auckland
Offline Naekyr
« Reply #10 on: March 04, 2019, 03:56:14 pm »
Dealer told me standrad procedure was to replace the chains, tensioner and pulleys
« Reply #11 on: March 04, 2019, 04:15:51 pm »
There are no pulleys......
Offline Naekyr
« Reply #12 on: March 04, 2019, 04:50:10 pm »
Just repeating what they put on the quote lol
« Reply #13 on: March 04, 2019, 05:19:40 pm »
A cause for concern if they can't get the quote right.
Offline Bailey918
« Reply #14 on: May 15, 2019, 09:17:09 am »
Hi, I'm also new on here as I have just bought a Mk6 GTI.
I had it in my mind after reading various sites that it was a 'must do' for the mk6.
But I was told by VW in Tauranga that the tensioners were not an issue that I should worry about and a good local Euro mechanic here who is a 'VW guy' says the same thing.
I'm not sure what to think now. I really don't want to wreck a motor but also don't want to spend upwards of $1500 if it's not needed.
Has anyone on here actually had the tensioner on their car fail?
Offline McDoof
« Reply #15 on: May 15, 2019, 09:54:24 am »
You'll find Vert will have seen a fair few motors that have blown up because of this issue.
In the USA there is a class action against VW that has been won. So the issue 100% exists. Choose to ignore it at your own risk.
https://medium.com/@autobahnaudivw/volkswagen-audi-timing-chain-settlement-recall-repair-reimbursement-information-c4abc4f5b359
Offline Bailey918
« Reply #16 on: May 15, 2019, 12:13:27 pm »
Thanks for the reply. I feel like I will get it done.
Just one other question for anyone who may know. Is there a way to tell if it's already been done?
Because I have the service history from Japan (been services 4 times there) but it's pretty vague.
Anything to look for? Parts numbers of newer tensioner models?
« Reply #17 on: May 15, 2019, 01:06:09 pm »
99% sure it won't have. There is an inspection plug to see the tensioner so yes it's possible to check.
PM me if you need the job done, have done lots and have also seen plenty of broken engines as a result of failed chains / tensioners.
I cannot understand dealers telling people it's not an issue. Not their problem I guess if your engine goes boom.
100% cause for concern!!
« Last Edit: May 15, 2019, 01:08:28 pm by 80 Vert »
Offline thomas.dq
« Reply #18 on: May 15, 2019, 06:35:19 pm »
Yes, mine failed on my 2010 MK6 GTI.
It was covered by the warranty at the time, thankfully. Strongly recommend you get it done.
1997 Mk3 Golf VR6
2010 Mk6 Golf GTI
Offline Audi_BTMan
« Reply #19 on: June 10, 2019, 01:25:00 pm »
is it specific year MK6's?
We just got a 2014 mk6 ( im guessing last of the MK6?)
