Author Topic: Mk6 timing chain tensioner  (Read 4750 times)
Re: Mk6 timing chain tensioner
« Reply #20 on: June 10, 2019, 03:21:29 pm »
is it specific year MK6's?
We just got a 2014 mk6 ( im guessing last of the MK6?)
Better check that? Mk7 started in 2013.
Current: 2004 MK4 R32
Past: 2010 MK6 GTI / 2007 B7 RS4 / 2006 MK5 R32 / 2005 MK5 GTI / 1998 MK4 GTI / 1997 B5 A4 MTM
Offline Audi_BTMan
« Reply #21 on: June 10, 2019, 03:53:34 pm »
im a twit, its 2012 my audi is 2014, must be monday.
Offline Naekyr
« Reply #22 on: July 26, 2019, 11:31:30 am »
I think it's up to May 2012 or something, after this they used a revised tensioner
Offline mark2 golf
« Reply #23 on: July 26, 2019, 12:32:20 pm »
I have a mk6 gti 09 and a q5 09 at work both with bent valves. I would change it if it was mine.
89 mk2 1.8t
97 mk3 gti 1.8t
02 Allroad tdi
99 s430 merc
90 190e 2.6
« Reply #24 on: July 26, 2019, 12:50:55 pm »
I've got a great running 2010 2L TSI engine with chain and tensioner replaced already available if they want to go the replacement engine route rather than rebuild.
Offline mark2 golf
« Reply #25 on: July 26, 2019, 02:01:17 pm »
I have just put new valves in one. How much do you want for it?
89 mk2 1.8t
97 mk3 gti 1.8t
02 Allroad tdi
99 s430 merc
90 190e 2.6
Offline Flavlus
« Reply #26 on: April 01, 2021, 01:49:57 pm »
99% sure it won't have. There is an inspection plug to see the tensioner so yes it's possible to check.
PM me if you need the job done, have done lots and have also seen plenty of broken engines as a result of failed chains / tensioners.
I cannot understand dealers telling people it's not an issue. Not their problem I guess if your engine goes boom.
100% cause for concern!!
Do you still do these? I messaged you. Thanks in advance
« Reply #27 on: April 01, 2021, 02:08:57 pm »
I do, just replied to you.
