Author Topic: C4 S6 died and wonít start.  (Read 4472 times)
Offline B5_Bandit
« on: March 30, 2019, 05:21:59 pm »
Hi everyone,
After some advice as I donít have a scanner handy. Today whilst driving down the road my C4 S6 died instantly. Iím not familiar with these cars however, Iíve tested the fuel pump relay and it works as should with 12v across the coil, Iíve bridged 12v and the fuel pump kicks in, when the engine turns over the rev gauge doesnít move. Any thoughts on these symptoms before I book it into a garage and let them find out the problem?
Re: C4 S6 died and wonít start.
« Reply #1 on: March 30, 2019, 05:33:08 pm »
My wild stab is crank angle sensor fault or pin dropped out of the flywheel.
Offline user2154
« Reply #2 on: March 31, 2019, 08:53:21 am »
You can check codes with a paper clip as per link below. You will find the relay box on the right side behind the firewall in the engine bay.
http://www.sjmautotechnik.com/trouble_shooting/ecuf20v.html#fcs4
The 4 digit fault codes will be displayed by the engine check light, simply count the number of blinks and write it down, then the next until you have a 4 digit code. The you may have to jump it again to get the next code, not sure, try and see.
List of fault codes.
http://www.sjmautotechnik.com/trouble_shooting/20vcodes.htm
There is enough information online to fix these cars yourself if you are that way inclined. Pull codes and I will help you find the information you need.
Another page with same info.
https://www.audiworld.com/forums/audi-original-s-cars-25/retrieving-ecu-fault-codes-please-learn-how-2893986/
« Last Edit: March 31, 2019, 09:10:34 am by user2154 »
Offline B5_Bandit
« Reply #3 on: April 19, 2019, 05:08:10 pm »
Thanks for that mate. Will attempt more fault finding over the weekend.
Offline URS4 Avant
« Reply #4 on: May 21, 2019, 11:16:42 am »
The G40 cam sensor is also known to fail, giving you a no go scenario.
