What batteries are people running ?
Started by Hughbugger, June 13, 2019, 10:53:49 PM
Hughbugger
What battery specs are recommended for an 08 GTI? From my online research there is a lot of variation in peoples opinions on the best CCA & Amps. For a daily driver is CCA big factor or is brand and chemical type a larger contributor to reliability? Is the added cost/weight worth it also? Thanks.
2010 - Scirocco 2L TSI
2009 - Tiguan TDI 4Motion
2009 - MK5 GTI Pirelli edition STG1
2008 - Mk5 TSI
The Red Warrior
#1
I went for high CCA and a good brand. Cheapest place I found was Mrpositive.co.nz
I?ll see if I can find a link to the one I got.
Here you go:
https://www.mrpositive.co.nz/bosch-s5-premium-din66zl-automotive-battery-680cca/
Hughbugger
Man that's some great value for money when compared to some of the Repco/SCA batteries. Is 680CCA needed? A lot of the people online have said 500CCA is plenty and its better to save the weight/money. Thanks for the link also.
2008 - Mk5 TSI
The Red Warrior
Possibly not needed, but my previous one (not a Bosch) was 550 CCA and lasted 3 years. So thought for the price I?d upgrade.
Plus I have a radar detector, phone charger and amp running 6 speakers all drawing current at start up.
I also think having your lights set to auto doesn?t help either.
dummer
I use https://www.batteryworx.co.nz/products/varta-din66-car-battery-780cca just because the bigger the better :o
I leave my dash cam running overnight and so far 3 years down the track still seems to be fine
Autostop sell Bosch batteries, much better than the NZ made crap everyone else sells.
Hughbugger
A good brand seems to be the common consensus. After shopping around, the upgrade from "Repco" branded to Bosch etc. is very minimal with the difference being ~$50 if that.
2008 - Mk5 TSI
