I'm not too sure on the specifics of the recall but isn't bypassing the fuel pump relay dangerous?
If you're for example in an accident and the car cuts out, that relay is triggered off the ignition coil and will also cause the fuel pump to stop. If you bypass it will just keep pumping fuel until you switch the ignition off.
