Author Topic: Passat failed WOF for towbar  (Read 9380 times)
Offline Pristle
  • vyf ster
« on: August 23, 2019, 11:43:49 am »
Well before going to the WOF shop yesterday, I checked through everything: a couple of new external globes; replaced connectors for O2 sensor; fitted new tyres & brake pads. All set.
No. Failed.  :(   Towbar. Same shop has issued the past 3 warrants, never an issue. But credit to them and a new team member, they checked it this time and found vertical movement. Turns out that the wrong towbar was fitted to the car by a previous owner.
I took the car to BestBars and they confirmed that the fitted unit is for a 4Motion car as opposed a FWD. The vertical dimension of the rear section of the chassis is different between the two, by about 35mm. Who knew?
Options are: remove it, replace it, or retrofit with some form of packing to take up the slack.
I have been thinking the latter, perhaps using some high density polyurethane. Any thoughts?
Offline Pristle
  • vyf ster
Re: Passat failed WOF for towbar
« Reply #1 on: August 25, 2019, 07:51:54 pm »
Grrr.....whoever fitted the towbar managed to strip 3 of the 4 bolts.
Offline the phantom
« Reply #2 on: August 25, 2019, 08:10:02 pm »
towbar? it's got to be steel to take the forces
Offline Pristle
  • vyf ster
« Reply #3 on: September 07, 2019, 10:59:22 am »
Perhaps you misunderstand. The towbar has vertical play, about 10cm at the ball. The inside height of the chassis rail in the 4Motion versions is about 10mm shorter than the FWD.
The idea is to place a slab of nylon or urethane (not the soft variety) underneath the arms of the towbar, between them and the bottom of the chassis rail.  A UK towbar vendor suggests a rubber wedge.
Have been to three shops this past week, none helpful. One suggested just cut the bar at the arms, another said "we'll cut the bolts off at the top and the nuts at the bottom. What's a nutsert?" The last one suggested maybe a panel beater as they'd be touch up damaged paint.
Offline brian
« Reply #4 on: September 07, 2019, 12:53:20 pm »
A nutsert is a nut installed like a rivet.................to be avoided if possible from my experience
I look on them as a last resort.
V̶W̶ ̶P̶o̶l̶o̶ ̶1̶.̶6̶  Škoda Fabia 1.0 TSI Race Blue
Offline Pristle
  • vyf ster
« Reply #5 on: September 09, 2019, 01:53:29 am »
At least you know what it is, the one shop I took it to had no clue.
