Author Topic: VCDS 5F Long Coding for Golf 7 Discover Pro  (Read 3704 times)
Offline MichaelGerrard
« on: October 06, 2019, 06:45:47 pm »
Hey everyone, I'm new to the forum and apologise if this has been asked before. I'm in New Zealand and bought a 2014 Golf 7 1.4tsi wagon with r-line kit. The car is a Japanese import. I'm in the process of trying to change the radio and navigation to work in New Zealand. I have managed to sort the radio out but I'm having trouble with the maps. I have downloaded the new maps and tried to install them, but get an error that says ROW doesn't match JPN. I have the Discover Pro radio. My question is this... does anyone have screen shots of their 5F long coding that displays the label for each bit under each byte? For some reason I can't see the details and information for my 5F long coding. If I could see the options for the bytes, then maybe I can ensure that I have the correct bits selected.
Offline Alittletuningco
Re: VCDS 5F Long Coding for Golf 7 Discover Pro
« Reply #1 on: October 06, 2019, 09:01:08 pm »
Canít be done.
Unit needs to be recoded to the region you are in, then activated and then new firmware and maps installed. Canít be done by a dealer, there are a few companies that can do it - we are one of them but are based in chch.
« Reply #2 on: October 07, 2019, 07:48:42 am »
You could try Autogravity in Dominion road, they specialise in converting nav systems.
