Author Topic: CECM Replacement - what part number?  (Read 2912 times)
Offline 4motioning
  • a.k.a Josh
« on: March 07, 2020, 01:00:38 pm »
electrical gremlins lead me to believe i need a new CECM for my mk6 golf r
does anyone know how much the part numbers matter in finding a compatible replacement?
currently has 1k0 937 087 M
mk6 Golf R
03 Mk4 Golf V6 4Motion
Offline 4motioning
  • a.k.a Josh
Re: CECM Replacement - what part number?
« Reply #1 on: March 07, 2020, 06:01:16 pm »
a bit of background, maybe someone could help with diagnosing.
had the cecm replaced a few years ago when the drivers headlight was stuck on highbeam.
the shop that did it didn't code the new one correctly which was annoying, but everything worked.
recently i had moisture problems in the headlight.
after sitting outside a couple of weeks when there was a bit of bad weather, i went for a drive and noticed the drivers side front indicator was permanently on.
had to disconnect the battery for it to go out.
also have a problem with the auto headlights function, with the headlights staying on during the day.
not shown in the code because I've had the switch on off and cleared the code.
normally shows fault:
light switch, implausible signal 01800
scan this afternoon attached.
Code: [Select]
VCDS Version: Release 12.12.0
Data version: 20130910
Saturday,07,March,2020,17:43:17:62939
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 14 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW299842
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
   Part No SW: 1K8 907 115 D    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH20---    Serial number:
   Coding: 0403000C1C0F0160
   Shop #: WSC 66565 257 00032
   VCID: 2F6DF537BEE897663D9-807A
2 Faults Found:
005782 - Powertrain Data Bus
               P1696 - 004 - Implausible Message from Steering Column Controller - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 108845 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 700 /min
                    Load: 49.4 %
                    Speed: 0.0 km/h
                    Temperature: 33.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.811 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0010 0100
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 013 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2742
   Revision: 05351113    Serial number: 00001103310877
   Coding: 0000024
   Shop #: WSC 00191 264 15243
   VCID: 2149030FF83C3116BBD-8074
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 163B800D092B0003681301E8901B00813D0000
   Shop #: WSC 01357 011 00200
   VCID: 76E30053C132E6AEBEF-8023
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 6ED32833B162DE6E76F-803B
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 M    HW: 1K0 937 087 M
   Component: BCM PQ35  H+  104 0614
   Revision: 00104 AF
   Coding: 40180ABA88251AC040080080340008E4436D008073208D60E48000240040
   Shop #: WSC 12345 000 00000
   VCID: 3B75D167BA907BC6811-806E
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 14031  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 060411 05  54  0403
   Coding: 0B30AD
1 Fault Found:
01497 - Bulb for Blinkers; Front Right (M7)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 109229 km
                    Time Indication: 0
                    Date: 2033.14.31
                    Time: 00:10:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.95 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 23031102680001
   Coding: 000180
   VCID: 275D1D175618CF26F59-8072
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 D    HW: 5C0 959 655 D
   Component: AirbagVW10G   013 0613
   Serial number: 003G7RA045XJ
   Coding: 00003951
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360_VW01.rod
   VCID: 3365F9479AC0B386591-8066
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME3C04215DZZZX
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME2158225DZZZW
   Crash sensor for side airbag; rear driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME520C0A6EZZZ/
   Crash sensor for side airbag; rear passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME7A1A1E23ZZZ/
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0080
   Revision: --------    Serial number:  90440KD40007E
   Coding: 189A140000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_SMLSNGKUDS A05001
   ROD: EV_SMLSNGKUDS.rod
   VCID: 76E30053C932E6AEBEF-8023
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Serial number: 0033024
   Coding: 830000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 871 B    HW: 5K6 920 871 B
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 570F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 080411F1000461
   Coding: 350003
   VCID: 306FF64B63D6889E243-8065
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 109229 km
                    Time Indication: 0
                    Date: 2033.14.31
                    Time: 00:10:37
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 4487AA9B076E043EF0B-8011
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: EADBA4230D8AB24EAA7-80BF
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5K0 959 701 E    HW: 5K0 959 701 E
   Component: Tuer-SG         009 2152
   Coding: 0004790
   VCID: 3467FA5B57CEB4BE40B-8061
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 251    3201
   Revision: 00H20000
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 109229 km
                    Time Indication: 0
                    Date: 2033.14.31
                    Time: 00:08:10
             Freeze Frame:
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 23.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 E    HW: 5K0 959 702 E
   Coding: 0005046
   VCID: 3561C75F5CB4ADB6775-8060
Address 55: Xenon Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1477980
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000022
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 D    HW: 5K0 959 703 D
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 D    HW: 5K0 959 704 D
   Coding: 0000144
   VCID: 3663C05341B2A6AE7EF-8063
End   ---------------------------------------------------------------------
mk6 Golf R
Offline 4motioning
  • a.k.a Josh
« Reply #2 on: March 17, 2020, 07:05:46 pm »
no one?
the only exact replacement modules ive found so far are ordering through VW for $1200, or from ECS for $400USD
the logic in me says that as long as its the same part number (1K0 937 087) the modification number shouldnt matter as long as its the same or newer.
im still unsure what the Z number means, but its not listed in the scan.
mk6 Golf R
« Reply #3 on: March 23, 2020, 11:28:33 am »
part numbers on the mk6 platform are very specific, there might be a crossover on CECM units one can attempt.
I'm not able to shed too much light on that at this stage. I have not yet had to play with the mk6 and CECM swaps.
b6 Passat (3C) and mk5 platform, I have done a few. Again only crossover on some units.
Offline 4motioning
  • a.k.a Josh
« Reply #4 on: March 23, 2020, 12:44:02 pm »
i did find a reference saying anything with a b,d,f,h,k,m,p,r or t version should work as long as the serial number is the same or higher.
1k is mk5 though right?
i found loads of 5k cecm's but really dont want to risk trying any of them
mk6 Golf R
« Reply #5 on: March 24, 2020, 02:34:30 pm »
The 087 bit is the important part, tells me you have a "highline" unit probably your car has xenon lights.
085 is low line and 086 mid line.
Any mk6 bcm with a suffix higher than yours will work as long as its 087xx etc
Offline 4motioning
  • a.k.a Josh
« Reply #6 on: July 13, 2020, 07:27:12 pm »
managed to pick up a cheap replacement thats a version P i think with the next serial number up.
seems to work fine just havent got it to accept the central locking from the key fob.
new cecm fixed the indicator stuck on problem, but not the auto headlights.
i think the rain light sensor may be busted or loose connection.
really unsure whats causing so many cecm problems.
some reasearch online suggests maybe a bad earth.
mk6 Golf R
