Author Topic: Getting to the park light bulbs  (Read 621 times)
Offline timewarrior
« on: March 08, 2020, 01:22:29 pm »
Hi Volks,
Iím having trouble getting to the park light bulbs in my Mk4 R32, the clip on the rear of the headlight is no problem to remove to get the back of the headlight unit loose but thereís no room after that to do anything with it. Any help would be appreciated, Iíve watched a dozen tutorials for the other models of Mk4 but thereís a lot more room it seems without the xenon unit, ballast etc. On the drivers side thereís barely room between the back of the headlight and washer bottle for a hand and then you can pull up because of the various connections above the unit. Passenger side thereís even less gap between the headlight and the battery cover.
Having to look at this now because previous owner installed LED park lights and they flicker non stop.
94 Golf VR6 Dusty Mauve Pearl
05 Golf GTI Diamond Black Metallic
04 Golf R32 Reflex Silver Metallic
"The more I know, the more I don't pretend to know"
Re: Getting to the park light bulbs
« Reply #1 on: March 08, 2020, 02:09:01 pm »
Did mine recently as well, I just removed the entire light unit which meant the bumper had to come off. I imagine the mounting points are the same for a standard golf and a r32. If so, it's just screws under the grille, in the wheel well, under the bumper and behind the lower vents. Then just 4 bolts holding the light in. There's probably an easier way to do this but it takes less than 10 mins to get the bumper off so not that big a job! Hope that helps.
There's a good picture here for bumper bolt location;
https://workshop-manuals.com/volkswagen/golf-mk4/body/general_body_repairs_exterior/bumper/front_bumper/removing_and_installing_bumper_cover_golf_r32/
« Last Edit: March 09, 2020, 09:24:49 am by stillcantplaygolf »
Mk4 Golf v5
Mk3 Caddy 2.0 TDI - sold
Mk4 Golf 1.6 - rip
Offline timewarrior
« Reply #2 on: March 15, 2020, 09:51:37 am »
Thanks mate, Iím going to have a crack at getting this bumper off today!
Offline timewarrior
« Reply #3 on: March 15, 2020, 06:19:37 pm »
Got the bumper off eventually, was slow going because everything feels brittle as. Most of the clips on the headlight plugs were already broken off and the ones that werenít broke today - not too worried about those. The bulbs they sold me at Repco didnít fit so Iím off to BNT tomorrow after work so fingers crossed I can get the right thing. The big bugger of the day was the cover on the xenon bulb housing on the passenger side only had one clip left, and although we didnít go near it, it broke when I picked up the headlight and thereís no way to make it sit in place. Will try to order one tomorrow. Everything must just get so hot around there and plastic doesnít last
Offline the phantom
« Reply #4 on: March 15, 2020, 10:05:25 pm »
that's why today's headlamps can't take higher wattage bulbs, I remember having 130 watt main beams in a (borrowed) Cressida for a magic nightime drive from Napier to Wellington
Offline timewarrior
« Reply #5 on: May 13, 2020, 09:52:06 pm »
I ended up getting two new xenon covers from Speed.co.nz for about $30 each and they took a week to arrive so that was pretty good. Replaced the broken one and the other side was fine so that was good!
