Author Topic: URS4 ECU  (Read 9256 times)
Offline portmanteau
Re: URS4 ECU
« Reply #40 on: June 05, 2020, 10:46:23 am »
I think you are about to hear a number of opinions about whether your guy should be going anywhere near other peoples' cars, and all of those opinions will be valid
Offline user2154
Re: URS4 ECU
« Reply #41 on: June 05, 2020, 06:47:08 pm »
Stock AAN ECU US$350 (these are from the USA so will be from a manual transmission vehicle).
Item 5 on the list.
https://forums.quattroworld.com/classifieds-parts/msgs/54261.phtml
I have a manual ECU in my auto and it works fine but it is chipped with PRJ chips. It is a later model IMMO ECU so you have to chip it to get around the IMMO function. Maybe a non IMMO manual ECU will work in a non IMMO auto vehicle with no chips? I do not know.
I don't know if the chips are auto or manual specific, my guess is any chipped ECU will work in an auto but YMMV. Do you have an auto or a manual transmission? It worked for me and it worked another, see post #7 in this thread.
https://www.s2forum.com/forum/technical/engine-and-turbo/86467-will-urs6-ecu-work-in-my-urs4-automatic
Another chipped manual ECU
https://forums.quattroworld.com/classifieds-parts/msgs/55833.phtml
« Last Edit: June 05, 2020, 06:58:06 pm by user2154 »
Offline URS4 Avant
Re: URS4 ECU
« Reply #42 on: June 05, 2020, 10:45:36 pm »
My car is a 6spd manual, 1993 with no immo. Thank you for the links, you seem to have a good nose for the right parts! I will still get the ecu specialist to check my ECU first, then if that fails chase one of these guys for a replacement. Mine is weird, when i turn the key i can still hear all the item clicking under the bonnet (n75, icv etc) like it did before, checked in the weekend and the G40 sensor flashes a led when wired of the plug. Fuel pump comes on and injectors fire just has no spark. So maybe something minor.
Offline user2154
Re: URS4 ECU
« Reply #43 on: June 06, 2020, 09:04:17 am »
According to the US forum the ECU ignition coil driver is NLA so it doesn't sound good if you have no spark. This is the demise of a lot of ECU's apparently.
Maybe you get lucky and it is just a broken trace. Would be interested to know what was wrong if they can fix it.
https://forums.quattroworld.com/s4s6/msgs/363346.phtml
Chipped ECU's normally go for about US$500 I think. Or buy a non-chipped ECU and get them to ship it to this guy in the US to chip it before sending it over. That's the way I would go.
http://www.efiexpress.com/catalog/
Offline user2154
Re: URS4 ECU
« Reply #44 on: February 01, 2021, 03:53:30 pm »
Did you get this fixed?
