1986 Audi coupe quattro
Am needing the engine (KG turbo engine) to gearbox bolts and front sub frame bolts.
Does anybody have any spare you no longer need?.
What size are they ie length, pitch etc?.
Would I be better off going into a bolt shop and getting what I need?.
On another matter, I intend fitting the engine into a non turbo engine room, I need to move the brake booster to the left side of the engine room.
The battery tray needs to be removed and the battery will go in the boot.
How on the ur quattro's is this done?, is there linkages I need to purchase?, have searched online but not having a lot of luck.
Cheers.
