Bolts
Started by Audi do, April 29, 2020, 09:59:54 AM
Audi do
1986 Audi coupe quattro
Am needing the engine (KG turbo engine) to gearbox bolts and front sub frame bolts.
Does anybody have any spare you no longer need?.
What size are they ie length, pitch etc?.
Would I be better off going into a bolt shop and getting what I need?.
On another matter, I intend fitting the engine into a non turbo engine room, I need to move the brake booster to the left side of the engine room.
The battery tray needs to be removed and the battery will go in the boot.
How on the ur quattro's is this done?, is there linkages I need to purchase?, have searched online but not having a lot of luck.
Cheers.
slowburn
you need the pedal linkage out of a left hand drive car, and a turbo coupe airbox will be a help too. not sure about the bolts.these guys are good for bolts and that...
https://www.coastalfasteners.co.nz
colingrant
In a RHD UR quattro there is a cross shaft from the pedal to the left side brake booster.
Audi do
Thanks guys, does anyone have pictures so I know what i am looking at?.
Does anyone have the engine to bellhousing bolts?.
slowburn
I have the pedal set up you are looking for.....when I go back to welly and get to my lock up I'll take some pics and measurements for you
I wanna keep it ,but happy to show you what you're looking for
Audi do
Quote from: slowburn on May 02, 2020, 03:00:08 PM
How did you get on?.
slowburn
I haven't been back yet, however, I am there tomorrow, so thanks for reminding me. I'll try and dig it out and get some snaps
slowburn
slowburn
slowburn
slowburn
slowburn
slowburn
sorry that last lot of numbers is blurry.... it looks like 812721115A the other number is clearer and I am guessing that this is a B3 piece as it has B3 stamped on it and the other number starts with an 89......hope this helps? you can see the linkage goes left to where the MC will have to be if you convert to turbo.....
Audi do
Thanks heaps for the pictures, this goes a long way to what I will need. I am thinking though to make an exhaust manifold, just need to find some steam pipe.
slowburn
it gets damnen hot, make sure you get a steel gasket too, anything else won't be up to it. and making one may be harder than you think. maybe try and find a proper one? they are kinda slim on the ground round here though. can take some pics of one if you want?. let me know if you get stuck, I might be able to help. the GT ones are different. the quattro ones are model specific
portmanteau
Quote from: slowburn on June 11, 2020, 09:34:06 PM
right on the nail!
https://www.ebay.co.uk/itm/Audi-80-GT-coupe-pedal-box-812721115A/223766093912
Probably not as complete as you need though?
322721115
Supersession(s): 811723115; 811721115K; 812721115A; 811721115A; 811805023E; 812805023C; 811721115G; 811721115L; 812805023D
slowburn
its a start? probably get the bits together based of the looks of the photos? maybe....
Audi do
Quote from: portmanteau on June 21, 2020, 08:28:51 PM
right on the nail!
322721115
Nice, might have to look into that.
00quattro00
Leave the brakes where they are and make a new exhaust manifold, the standard one is a piece of crap
Audi do
Quote from: 00quattro00 on September 09, 2020, 06:49:13 PM
That is what I am fixing to do, I suspect getting the car certified/revinned will be easier as well doing that.
