With acres of crap in two yards to look at this could take a while but the suffering placed on my wife would be too much haha so best to have a quick look around and get on with the job at hand.
Righto lead the way to what I came here for, through several buildings and work shops, down a narrow path to a small yard there it was sitting beside a shed.
What a thing of beauty!
So what are we here to get? Correct, its manual operated 2 way tilt / slide sunroof. Direct bolt in to a Mk2 Golf which was never offered with a tilt / slide roof.
Was a bit concerned that it would be rusty due to the length its been sitting but nothing was visible from the outside and I'd already decided anyway that no matter if rusty or not I was going to save it and make it work.
Brought a bunch of tools with me that I thought I might need. As expected the roof no longer operated, it would try to open a little but I didn't force it.
Managed to open it enough to slide the interior panel back and disassembled it from there, easy once the main panel was out.
Removed all the cables and guides as well as the crank mechanism, with just an empty hole in the roof you could easily see the metal sunroof box was exactly the same as a Mk2 Golf.
Placed an old windscreen sitting nearby over the hole, collected all the parts and job done.
Had a chat with the owners and asked if they had any other VW's, he said there's a Santana somewhere haha.... umm ok yeah maybe not. With that we hit the road, a really memorable experience going there.
Back to Auckland via a totally empty Ohakune and Taupo.
Once back time to strip the paint off, first mistake. Used a stripping disc which even using lightly put too much heat in to the paper thin metal.
Thankfully I noticed it early on and stopped, paint stripper on the rest to bare metal. Sandblasted the inside frame and acid washed the whole thing.
Found a small area of rust that needs repair, much better than I could have hoped for. The black circle is a low area most likely caused by my stripper disc as the panel was straight before I started.
Had to remove a section of the inner frame to get at the rusty area that needed repair, the main outer panel is only 0.7mm so very thin and mig welding this would distort the crap out of it so I'd be trying to tig weld this.
