He certainly does do a good job in that video doing it one handed.
Agree with 80 Vert.
Members on here like to help each other out by and large I’ve found. Treat them nice and don’t be stingy. You’ll probably even make some friends.
Is the different wiper stalk necessary? When I upgraded to the Mk6 MFSW in my Mk5 that didn’t have a MFSW I didn’t change it. It just means that the up/down buttons on the steering wheel do the same as the toggle button on the stalk.
The video doesn’t show using VCDS to do the steering wheel adaptation either, which I had to do due to moving the slip ring.
If you find someone in Wellington that’s prepared to do the coding and adaptation for you (on here or the dealer) then you can install all the parts yourself and then still drive to meet them. You just won’t have power steering (or have the MFSW buttons working yet).
