Author Topic: Audi A1 / Q3 Cruise Control Retrofit Kit  (Read 1279 times)
Offline Daz42
« on: August 10, 2020, 08:39:15 pm »
Hello, would anyone be interested in an Audi A1 / Audi Q3 Cruise Control Retrofit Kit? Includes the full indicator/wiper/cruise stalk and bottom steering column cover. Full instructions provided including how to code it using VCDS. If fitting to an A1 a single wire needs to be run to the engine ECU, if fitting to a Q3 no wire is needed. The job is quite easy and takes 2-3 hours depending on if you need to run the wire. If you live in Auckland I might be able to fit it for you but if you need the wire run you would need to take it to an auto electrician or you could do it yourself.
