Author Topic: JOM coilovers avaliable for GOLF/GTI $850  (Read 110 times)
Offline Critter-Cool
« on: August 24, 2020, 10:15:21 pm »
Hello everybody,
New time Newbie here with some JOM blueline coilovers for sale
2 year warranty
NZ based, no delays.
Details:
JOM Coilover Suspension Kit
-Handling Performance Upgrade
-Wide Range Of Height Adjustment
-Perfect Fit
-From JOM Germany
-European TÜV Certificate
-Height Adjustable Front & Rear
-Galvanized Steel Housing
-Includes Spanner Wrenches
-Includes New Bump Stops & Dust Boots
-EPS Powder Coated Springs
-Brand New & Complete Coilover Kit.
Height adjustable while installed, there is no need to remove the suspension from the car to adjust the height of the car.
Fits the following models:
VW Golf / GTI MK4 (models 1999-2005, NOT R32, 4 Motion 4x4)
VW Jetta / GLI / Wagon MK4 (models 1999-2005, NOT 4 Motion 4x4)
VW New Beetle (models 1998-2010, NOT 4 Motion 4x4)
Lowering Range:
Front: 20mm-100mm / 0.8"-3.94"
Rear: 20mm-70mm / 0.8"-2.76"
For all vehicles stated in this offer: front axle lowering below 40mm / 1.57" requires shorter drop links which are not included in this kit.
Axle Load:
Front: 1020 Kg / 2249 lbs
Rear: 1025 Kg / 2260 lbs
CNC wound SAE 9254 racing springs were found to be the longest lasting spring on the market that showed no tendencies to sag or weakness.
Spring and damper rates that focus on exceptional handling characteristics and great drivability are used.
The results are outstanding ride quality and unmatched razor sharp handling.
Is it for daily use in street traffic or for professional car shows, there is always the right amount of ground clearance with the high quality coilover suspension kits from
JOM.
Not only can the JOM coilovers be individually adjusted to suit a very wide variety of different driving conditions, the adjusted height can also be changed at any time.
Things get really close to the ground? – There is always sufficient suspension room remaining even at the lowest settings with JOM adjustable coilover kits.
Thanks to a high quality shock absorption system, you do not lose any contact to the road. You are always on the right track with the popular Street coilover suspension kits from JOM.
