Author Topic: Mk5 GTI - Battery Removal without turning off power supply?  (Read 1428 times)
Offline Jasera
« on: August 25, 2020, 07:35:58 pm »
Hi All,
I need to do a DSG change on my MK5 which requires the battery and its housing to be disconnected.
However, I don't want to completely shut off the car power supply as this will void my tune (which I want to avoid due to the distance to travel + retune fee)
I understand this is not the safest thing to do of course, but has anyone got some ideas advice around this?
My plan would be to put a trickle charger at the end of the ground & live wires and disconnect the terminals which should keep it alive, and then carry out the service.
Thanks.
Re: Mk5 GTI - Battery Removal without turning off power supply?
« Reply #1 on: August 25, 2020, 08:12:17 pm »
No need, I never remove the battery or battery tray.
Easy enough to change filter without removing either.
Offline superfueler
« Reply #2 on: August 28, 2020, 10:46:21 am »
Do you want to pull the whole gearbox out or just do a fluid and filter change?
« Last Edit: August 28, 2020, 10:49:14 am by superfueler »
