I've got ABF swapped MK2 (was originally an 8v) and my throttle cable is too long. The adjustment is maxed out to get it tight enough and the stopper on the floor of the pedal is still 1cm off so when you plant your foot it bents the bracket that holds the cable and it comes flying off. Does anyone know what cable is sorter? I had a spare lying around that is the same length and even brought a new cable as I thought both mine might be stretched but it exactly the same. 192 721 555 A, 1084mm is what I currently have.
