Author Topic: Aircon compressor noisy  (Read 899 times)
Offline superfueler
« on: September 17, 2020, 09:38:18 am »
Ok, so my R32's aircon compressor started making a whining / slight grinding noise about a month ago when on, selecting econ on the climatronic, noise goes away (obviously with clutch then disengaged on compressor)
I have been driving with the a/c off for most of the winter, occasionally running it just to keep it healthy, now the noise is getting more prominent. Will want it operational for the summer obviously.
I take it this will be the compressor bearings shot. From what i have seen on research, there's 2 sets of bearings in the unit, 1 set for the compressor and 1 for the clutch.
Which will be better, getting the bearings replaced OR just getting a replacement compressor? Anyone able to point me in the right direction?
Cheers.
Re: Aircon compressor noisy
« Reply #1 on: September 17, 2020, 08:56:12 pm »
Thrust washer most likely causing excessive end float. Grab the nut on the electro clutch with vise grips and pull in / out. Should only be a tiny bit of play. (As in barely anything)
« Reply #2 on: September 17, 2020, 09:00:22 pm »
I've repaired loads of them when mk4's were still expensive cars.
Offline superfueler
« Reply #3 on: September 18, 2020, 10:30:34 am »
Thanks John, i will have a look.
Not much space in te engine bay to get to it from above, perhaps it'll be easier from underneath the car. How difficult will this thrust washer be to replace?
Mk4's are still expensive cars.............everytime i open my wallet at the parts store and at the pump.  :D
« Reply #4 on: September 18, 2020, 04:57:06 pm »
Do it from underneath and take the drive belt off
