Author Topic: Audi 2010 8P S3 DRL LEDS with a Japanese import  (Read 4668 times)
Offline daniel53
« on: September 18, 2020, 04:07:55 pm »
Hey guys,
Iíve got an import s3 as above. The leds work but not as I want them too. I would like them turned on when lights are in auto like Nz new cars do. Iíve tried the coding in vcds but nothing seems to change it. Iíve read some posts and other say itís turned off because of in Japan.
Surely Iím not the first one to want to do an S3
My thoughts were if they are disabled maybe I need to get the security access code to change the setting.
Any help would be appreciated itís doing my head in.
Thanks
Offline Esque5
Re: Audi 2010 8P S3 DRL LEDS with a Japanese import
« Reply #1 on: October 20, 2020, 07:14:33 pm »
Did you manage to sort this out mate? I got my Japanese import SQ5 DRL's working after a lot of VCDS digging.
Offline Vwag
« Reply #2 on: March 03, 2021, 09:58:14 pm »
Anyone have any luck? Same problem here!
« Reply #3 on: March 23, 2021, 03:42:43 pm »
found a very odd trick out with a scirocco R a month or two ago. Same thing, NZ new Scirocco and Golf R the LED lights up, the Jap imports do not. So figured out (can't recall exactly what I did in the end)
But got it working, I did not use VCDS or coding at all.
Offline ltani
« Reply #4 on: March 25, 2021, 02:52:34 pm »
Can you recall, even vaguely, what you did? I have the same issue. DRLs only on with parking lights or headlights.
Audi S3 8P - Stock
Audi A4 B8 - Integrated Engineering Stage 2
Audi TT 8J - Stage 1
