Author Topic: couple issues with my mk4 r32, any help is appreciated  (Read 1232 times)
Offline mitchr32
Re: couple issues with my mk4 r32, any help is appreciated
« Reply #20 on: October 04, 2020, 11:41:17 pm »
Unless your lights are wired differently to mine, the innermost lights in each cluster should be park and high beam. The outermost lights are low beam. And your foglights are the ones underneath the indicators.
In which case your foglights aren't working at all (no big deal), but your LH park light isn't working in those pics. So check the fuse I mentioned above, because the LH tail light and LH park light share the same fuse.
Ah ok, didn't know which lights were which tbh lol, will definitely have a look at the fuses tomorrow morning, thanks a lot!
2003 Golf R32 4dr - Deep Black Pearl
Offline mitchr32
« Reply #21 on: October 05, 2020, 09:20:40 am »
i think i found atleast part of the problem-
fuse 23
Offline superfueler
« Reply #22 on: October 05, 2020, 04:56:18 pm »
Now to find out what made the fuse pop.  :D
Fuse 23 is for the left park lights according to the mk4 fuse diagram.
Like Louie has mentioned earlier, the wiring insulation inside the headlamps get brittle with heat and start shorting out. Perhaps start off with a new fuse whilst having the headlight connector disconnected and see if the tail lights work, then connect the headlamp and see if the fuse holds OR pops again. Gotta love mk4's hey......
« Last Edit: October 05, 2020, 05:02:33 pm by superfueler »
Offline LouieP
« Reply #23 on: October 05, 2020, 05:31:36 pm »
Does the car have led number plate lights and led park lights?
2014 MK7 Golf GTI - Pure White
1996 MK3 Golf VR6 - Black Magic Pearl
Offline mitchr32
« Reply #24 on: October 06, 2020, 03:30:13 pm »
yep, took it to a shop today and the fuse 23 did pop again, the guys said there are some exposed wires that lead to the headlight (which is probably causing it to pop?), and no power at all going to the rear parking light, so I'll take that to a electionics guy and get that fixed, nothing too major i don't think!
Offline mitchr32
« Reply #25 on: October 06, 2020, 03:30:42 pm »
i don't think they're LED
