Author Topic: b5 replacing instrument cluster - any coding required?? SOLVED  (Read 739 times)
Offline RayRay
« on: October 09, 2020, 03:11:30 pm »
So after watching you tube and seeing its super easy to change out an instrument cluster (not like a heater coil omg!!), I bought a replacement for mine for a quick cheaper way to fix the dead pixels....will fix the original at some point as it has white gauge surrounds but I am impatient and wanted it working quickly and already spent enough on the new/old girl!! Is it a girl, hmm no, rampant pre-teen boy more like, taking jumps he can't handle on his bmx, cruising the neighborhood playing spacies ...oh side tracked, yes i am that old!! ;D
Cluster is still on its way but then I realised that maybe there is some coding to do for a different cluster......can can anyone confirm this or not?
thanks (ps searched vask already, not further afield yet but i know you guys are super helpful from what i have read already  ;))
« Last Edit: October 12, 2020, 07:15:02 pm by RayRay »
2000 A4 B5 1.8TQ Sport AJL man sedan NZ - driving
2006 BMW E91 325i M-Sport tip touring JPN - neglected
1991 BMW E30 325i M-Tech1 man sedan NZ - sold and cried
Re: b5 replacing instrument cluster - any coding required??
« Reply #1 on: October 09, 2020, 06:53:31 pm »
Yes it will require the immobilizer to be matched.
Offline RayRay
« Reply #2 on: October 09, 2020, 07:58:33 pm »
oh shoot, I have a spare cluster then :-\
« Reply #3 on: October 09, 2020, 08:34:36 pm »
I'm not familar with the procedure but this might help:
https://www.audizine.com/forum/showthread.php/890183-Audi-A4-B5-cluster-swap-VCDS-problem
and
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_II_Immobilizer_Swapping_(Instrument_Cluster)
I have VCDS but that all looks slightly scary to me. Would hate to render your car undriveable!
« Reply #4 on: October 09, 2020, 08:39:52 pm »
If the replacement cluster has a good screen it's probably more practical to have the screen swapped over. Does require some delicate solder work I understand. Robinson Instruments can do it (for a price).
« Reply #5 on: October 09, 2020, 09:46:26 pm »
You just need to find someone with VagTacho to get the pin code from the cluster and then use vcds to re code it.
Offline RayRay
« Reply #6 on: October 10, 2020, 08:42:22 pm »
and
all very valuable info, thanks gents,
« Last Edit: October 10, 2020, 11:58:15 pm by RayRay »
Offline RayRay
Re: b5 replacing instrument cluster - any coding required?? SOLVED
« Reply #7 on: October 13, 2020, 11:14:34 pm »
i like the black >:D
