Author Topic: Low compression - Golf 2010 1.4 tsi 118kW  (Read 839 times)
Offline golfindownunder
« on: November 05, 2020, 05:14:54 pm »
Hi,
My daughter had a check engine light come on a couple of days ago and she took the car in to a garage in Auckland city. They scanned the car and came up with an error code P0301. They advised a change of the coil on cylinder 1 and replacing all the spark plugs, which she duly did.
However, the light came back on yesterday, along with the engine shaking while running. I took the car in to a garage in Henderson and they did a compression test which came up with low compression in cylinder 1. They advise that it could be a piston or ring issue and quite frankly recommended selling the car.
Before I do that, I'd like the expert opinions of this forum's members on:
Is it reasonably easy and cost-effective to source a replacement engine which does not have the issues of this particular model (the CAVD engine?)
Which year/engine code would you suggest?
Would the computer have to be coded to accept the replacement engine?
Any alternative suggestions?
Many thanks
Offline The Red Warrior
Re: Low compression - Golf 2010 1.4 tsi 118kW
« Reply #1 on: November 05, 2020, 07:20:30 pm »
CAVD is the turbo and supercharger version correct?
See my previous post about this car:
http://www.vask.org.nz/index.php/topic,45207.msg465009.html#msg465009
« Last Edit: November 05, 2020, 07:23:53 pm by The Red Warrior »
« Reply #2 on: November 06, 2020, 09:08:31 am »
Yes, this is the same engine! Unfortunately, the car is a Japanese import, so the local dealers will probably not want to have anything to do with it.
Offline portmanteau
« Reply #3 on: November 09, 2020, 09:16:38 pm »
Many thanks
CTH/CTHD is I belive the "improved version" of your engine
I have one for sale from a 2014 Tiguan done 86,000km but it is not cheap
read all about your problem at the following link - this is just one of many sites that google should be able to find for you:
https://www.grantwalker.com.au/volkswagen-cavd-engine-problems/
"There is a solution. in 2012 Volkswagen rectified this problem by upgrading this engine to the CTHD engine. This engine was released with upgraded pistons and piston rings, oil squirters, a superseded timing chain tensioner and a few other tweaks. This is a much more reliable engine and does not share the same problems as it’s predecessor. With minimal modifications (approx 2-3 hours) the CAVD engine can be replaced with the late model CTHD."
Offline gtyler
« Reply #4 on: January 15, 2021, 12:27:48 pm »
Hi, do you still have the CTHD for sale?
Offline portmanteau
« Reply #5 on: January 15, 2021, 12:34:47 pm »
PM sent
