Author Topic: new brake pads and now my clutch is wierd  (Read 541 times)
Offline heat
« on: December 02, 2020, 05:48:00 pm »
Hi can anyone  help, I got new brake pads on my mk4 golf and noticed immediately my gear change was weird afterwards, just more resistance to put in gear.  And sometimes clonking.
My mechanic who is not a VW mechanic thinks I'm imagining it. I took it back and I thought he was going to bleed my clutch but he lubricated the hydraulic pin. I think he's taking the piss.  Is it possible that it could affect my clutch?   So now my clutch which was fine b4 is juddering as well.  Its hard being a girl
« Last Edit: December 03, 2020, 01:39:54 am by heat »
Offline Gordo
Re: new brake pads and now my clutch is wierd
« Reply #1 on: December 02, 2020, 07:34:24 pm »
What area are you in, might be someomne close who can check and back you up on it.
They are separate systems, so most unlikely to be related, but stranger things have been known to happen - even co-incidence. As normal practice, it's advisable to change the fluid as part of the process, if not following the 24 month recommendation.
Is there a chance the mechanic who did the brakes could have taken it out and abused the clutch - or that he simply changed the seat position and you didn't get it back in quite the same position and aren't depressing the clutch correctly as your timing is a little out/
Offline heat
« Reply #2 on: December 03, 2020, 01:22:12 am »
  Yes,  probably thanks, good answer. That's exactly what happened no doubt. I've got someone to look at it tomorrow, though.
« Last Edit: December 03, 2020, 01:42:03 am by heat »
Offline fast4motion
« Reply #3 on: December 03, 2020, 09:15:24 pm »
From memory the Mk4 Golf clutch and brakes share the same fluid reservoir. So the mechanic probably managed to get air into the clutch line while bleeding/topping up the brake fluid after replacing the pads.
Offline Gordo
« Reply #4 on: December 04, 2020, 01:31:20 am »
Ah, that would make perfect sense, from what the lady described. Not something I would have thought of, not being a Golf aficionado
