Author Topic: Clarion 318sdcw - Help  (Read 1992 times)
Offline BobLobl4w
« on: January 14, 2021, 05:28:07 pm »
Hey all,
I'm the thrilled new owner of a Mk6 gti, being fresh off the boat it's stuck in Japanese showing me a lovely road map of Osaka.
I've done a bit of goggling and tried using translate but I can't for the life of me find whether there is a setting to change the language to English.
Does anyone have any experience with these stereos?
I'd rather not replace the stereo right away as I'm already getting the timing chain tensioner done in the next week so any help would be appreciated, otherwise I guess I'll just bite the bullet and get a new head unit.
Offline Dreamliner
Re: Clarion 318sdcw - Help
« Reply #1 on: January 14, 2021, 09:47:16 pm »
First of all,
Welcome to MK6 GTI.
as far as i know, the stock touchscreen enabled headunit by Clarion does not have language options.
I still have the unit, i went to each and every option, and just gave up.
I now use it as a glorified bluetooth receiver and just play music through bluetooth from my phone.
Regarding the tensioner, where are you doing them at what price?
might want to hit up John / Vert (on the forum) if you haven't already.
Cheers,
Peter.
2010 GOLF GTI MK6
Offline BobLobl4w
« Reply #2 on: January 14, 2021, 10:33:32 pm »
Thanks, I've had much the same luck - played with everything with no success. Will just look to replace I guess.
Tensioner is going to be done through dub world in Christchurch, have been given $650-$850 depending I'd the housing cracks or not, pretty happy with that price. Others have quoted between $1,100 and $2,500.
Offline Dreamliner
« Reply #3 on: January 15, 2021, 01:30:00 pm »
What is actually included in that chain tensioner change?
is it literally just the tensioner? or are you doing the chain as well once you are in there?
Early chains are known to also prematurely stretch, and had revisions, so doing it while you are in there (i mean, it doesn't increase labour almost at all) might be a good idea.
2010 GOLF GTI MK6
« Reply #4 on: January 15, 2021, 04:19:14 pm »
They can't be doing it all, the parts alone cost that if genuine and you should ONLY use genuine for this.
Offline coons
  • Sam
« Reply #5 on: January 19, 2021, 08:55:43 pm »
That radio is junk, can't be changed to english. You can get cheap replacement radios on TradeMe like this - https://www.trademe.co.nz/a/motors/car-parts-accessories/volkswagen/listing/2944794752?bof=EoIv3RZx
Or for a couple of hundred more you can get one that does CarPlay etc.
Mk3 Golf 1.8T
Honda GB600 Cafe Racer
Offline Bruce_Lee
« Reply #6 on: January 21, 2021, 07:55:48 am »
Hi there,
I have a Mk6 Golf Japanese import and I bought an RC330+ from Aliexpress, however when I pulled out the factory stereo (Clarion NX809) I found completely different wiring than what I was expecting (can't post image for some reason), definitely not plug and play.
I can figure out the main wiring (power, speakers etc) but the new unit requires CAN bus to detect ignition on, not sure how or where to find this. Would appreciate any help?
Thanks.
Offline coons
  • Sam
« Reply #7 on: January 21, 2021, 05:13:09 pm »
Keep pulling the loom out of the dash - normally those Clarion radios just use an adapter harness, but sometimes it can be quite long, and the OEM harness is hidden deeper down in the dash.
Mk3 Golf 1.8T
Offline Bruce_Lee
« Reply #8 on: January 22, 2021, 01:18:25 pm »
Thanks I will give that a try, appreciate your help.
Offline Bruce_Lee
« Reply #9 on: February 01, 2021, 08:55:10 am »
Thanks for the tip, connector was tucked down the back, new stereo now installed and working great.
Cheers,
Offline JaseNZ
« Reply #10 on: February 16, 2021, 07:13:14 pm »
Yup I put in the RC330+ from Aliexpress when I had mine, Easy plug and play and gives you android auto and airplay.
Don't bother with the one in there its junk.
Ding Ding Ding Ding Ding : Ice cream man , Ice cream man
