Everything crapped out when my AC died, 2005 GTI 57kmCompressor, TX valve, high pressure switch, expansion tank, various seals etc$$$$
https://www.rkxtech.com/collections/air-conditioningBoth our 2006 Tourans required the valves doing; My NZ New one at 115K, wifes import at 170K. no other problems since fitting the RKX valves. I'm sure they're available other places too.VW only sell the compressor, and have ripped people for plenty of them too! The valve in the most common failure in the MK5 platform.
In a lot of cases AC is a bit of a mystery meaning lots of people get sold things they do not need.Did another recently, degas, new valve and re gas. ack to cold AC.Look at the label on the compressor for the model number.
How did you pin-point the problem individually?
Do you do the degas and regas yourself John?Are there any laws in NZ about a DIYer doing it?
Ordered the valve for the Zexel pump. Hopefully it's a easy change (broken the connector release tab over the weekend )
Holy moly that seems like a lot, what did they replace?
