Author Topic: Wheel spacer advice  (Read 133 times)
Offline heylinb4nz
Wheel spacer advice
« on: April 08, 2021, 08:25:27 pm »
Fitted some 3mm spacers to front wheels on RS5 (to give some more caliper clearance). Noticed the spacer is smaller in diameter than the wheel mounting face and hub face....by about 30mm. Consequently the outer part of wheel face isn't  flush with hub. (ie unsupported). Is this a) safe and b) normal.
Pic here
https://www.a5oc.com/threads/wheel-spacer-hub-to-wheel-face-gap.176458/#post-1619359
« Last Edit: April 08, 2021, 08:27:04 pm by heylinb4nz »
