438bhp Skoda!
Started by RobClubley, October 16, 2006, 08:22:19 AM
RobClubley
There's a guy over in the UK who's having a little bit of work done on his Octavia 4x4.
It started with the 1.8t 150bhp engine...
Also for those interested here's a bit more detail on the spec but it's by no means inclusive.
GT3071R with CNC machined inlet
Stainless steel equal length manifold
Stainless steel downpipe and decat
Inconnel valves with 1mm bigger inlet
Pauter rifle drilled rods
JE overbore pistons
630cc Injectors
4 bar fuel pump
Oil pump
Coolant run on pump
Lots of other bits (bearings etc..) to make the engine like new
Custom Code Phase 3
For the gearboxI'm having a TT 6spd gearbox along with driveshafts and other minor bits that are required which will be fitted with a Stage 3+ clutch and flywheel from Spec.
Awesome!
Original source:
http://www.vag20v.net/forums/index.php?showtopic=2134&st=0
