Author Topic: How do you know what version v6 tdi engine is in a touareg?  (Read 485 times)
Offline B5Passat
« on: January 29, 2022, 06:26:13 pm »
Some listings in trademe are listed as having the engine as 150kw, 180kw and one as 193kw. It's the listings that don't say is the problem
Offline oem.minus
Re: How do you know what version v6 tdi engine is in a touareg?
« Reply #1 on: January 30, 2022, 03:12:56 pm »
Jump on carjam and search the rego - 99 times out of 100 it will give you a power number.
06 NZ MK5 GTI - Sold
07 NZ A6 3.2 Avant - Sold
07 NZ RS4 Avant
« Reply #2 on: January 30, 2022, 03:47:04 pm »
True although not sure how reliable those are though. Certainly not in the case of the facelift B5 A4 1.8TQ which is listed as 110kw but is actually 132kw.
Offline wilco
  • Ted the Mechanic
« Reply #3 on: January 30, 2022, 09:33:19 pm »
Carjam nearly always lists the engine code, I usually just look that up in wiki.
« Reply #4 on: January 30, 2022, 09:40:43 pm »
Good tip Steve.
Offline B5Passat
« Reply #5 on: January 31, 2022, 12:46:17 pm »
Thanks guys. I'll past it on to my son although he is now looking at some v8 Touaregs
