Radio has no sound! Help
Started by nikhilg12, June 12, 2022, 03:29:25 PM
nikhilg12
Vehicle - 2013 Golf MK7 TSI
Infotainment unit works with radio and everything else displayed, however the sound does not work intermittently. Sometimes when i start the car it works like the sound comes through and some days it just doesn't. It's very random. If I turn off the ignition and start again, it sometimes works and sometimes doesn't.
Is this a common issue with the infotainment? Its a Jap import. Issue started happening 2 days ago. This morning i went out and it worked. Then on the way back from our supermarket trip again no sound.
HELP!!
2013 MK7 Golf 1.4 TSI
The Red Warrior
When this happens, try changing the source (ie from radio to SD card and then back to radio).
Also, does it tend to happen if you have just had the car going recently, for instance go to a gas station and it works but after you get back in after filling with gas then sometimes it doesn?t work?
Pristle
Defaulter83
I am currently facing the same issue, i had opted for the MBI when i bought the car. The obvious last resort for this is infotainment system replacement. Another way to make it work is when the infotainment system is running long press the menu button>click on updates>select sd card option (wait for 5-6 seconds)>press the radio button. This is a hack I saw on youtube works though but is annoying specially if driving short distances.
nikhilg12
Quote from: The Red Warrior on June 13, 2022, 08:45:30 PM
I have tried that and it doesn't work. It's very random. Yes it works and doesn't work. Last couple of days it mostly hasn't worked at all.
nikhilg12
Quote from: Defaulter83 on June 15, 2022, 01:11:46 AM
This didn't work at all  :'(
