If you have to two-motor recirc version, one of the flap motors is stuck (will usually log a code) and when it tries to adjust the recirc amount, one of the flaps doesn't open.
Try turning the recirc on and off and see if it make a difference.
If it's REALLY a 2007 (by VIN, not rego), I'd have thought it would have the single motor version, in which case the mechanism may have failed.
If you take out the glovebox, you can see the flaps/mech.
