RS4 B8.5 - Fault Codes
Started by Pjai, May 25, 2023, 06:36:01 PM
Pjai
Hi all,
I just did a scan on my RS4 that I recently picked up and found these two codes below,
Is it something I need to action right away? no engine lights on the dash, but I did experience twice the car stalling at cold idle.
2 Faults Found:
7901 - Right Engine Mount Solenoid Valve (N145)
          P1575 00 [108] - Short to Plus
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 254
                    Mileage: 61239 km
                    Date: 2021.03.19
                    Time: 17:08:24
                    Engine RPM: 1224.00 /min
                    Normed load value: 16.1 %
                    Vehicle speed: 29 km/h
                    Coolant temperature: 98 ?C
                    Intake air temperature: 31 ?C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 13.970 V
                    Unlearning counter according OBD: 40
                    CAN status - engine control module-Bits 0-7: 0
                    CAN status - transmission control module-Bits 0-7: 0
                    CAN status - brake control module 1-Bits 0-7: 0
                    CAN status - brake control module 2-Bits 0-7: 0
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
2698 - Fuel Pressure Sensor (G247)
          P0192 00 [032] - Short to GND
          Intermittent - Not Confirmed - Tested Since Memory Clear
Alittletuningco
Top one - engine mount is dead - both need replacing, known issue as they wear over time. Consider upgraded mounts from somewhere like 034Motorsport.
Bottom one - sound like your fuel pressure sensor is not happy - from memory its mounted under the intake manifold on the fuel rail - cheap part to replace, a little time consuming to do so (unless you are handy on tools, and can do it yourself). Again fuel codes are worth investigating further as failure can lead to much worse consequences.
le mans
If you bought it from a dealer take the car back and get them to sort it.
Alittletuningco
Quote from: Pjai on May 26, 2023, 07:51:35 PM
Thanks!
Is this the sensor?
https://www.germanautoparts.com/bosch/14/06j-906-054-b
Looks like it - easies thing is to ping Audi and ask for the part number also
