How To: Mk2 Golf/Jetta up-rated headlight loom
Started by rambo_005, February 07, 2007, 04:11:13 PM
rambo_005
This will help get the extra 2-3 volts lost in the factory loom to your headlights :)
You will need:
1. A 30-amp switching relay
2. Fuse holder
3. 20-amp fuse
4. Blade connectors
5. Ring connectors for connecting to the battery
6. Yellow in line butt connectors
7. 20-amp cable
8. Light duty cable
9. Cable ties and tape
Note: This diagram only up-rates the dipped beam on your lights, you can do the same for the main beam (and spots if you have them) but you will need to have the wire that currently supplies the main beam switching the relay.
