Hi Guys,
Just pick this up. 05 paddle shift.
Go into get this done on the 14th of Dec,
Tuning
Stage 2 Tune (with the inclusion of de-cat pipes and cold air intake)
+40hp @ Peak
+60nm @ Peak
The addition of the cat delete pipes massively opens bottom end torque delivery and give the car a much better power curve across the range, better throttle control via a linear throttle spread and better off the line drive..
Exhaust
A full exhaust system from Milltek will consist of cat delete pipes and a cat back combined … Depending on the level of sound your after we’d recommend the non-center resonated cat back they sound by far the best – the resonated center set up is a bit too quiet for most, especially if you really want to hear it bark when you’re on the gas, conversely when just cruising about on light throttle the system is very compliant.
Intake
We have used the EVOMS brand on S4’s in the past and find they are a great fit, look good, add a nice front-end growl and importantly they hugely aid throttle response.
Looking forward to the journey
Cheers Smiladon
