Author Topic: Stealerships quote way too much for Temp sensor  (Read 505 times)
Offline dimistyle
    • MotoBravo
« on: March 21, 2005, 03:26:15 PM »
My water temp gauge has been playing silly buggers and form all the Passat forums the obvious problem is the Temp sensor at the back of the head :(
Quick search on the Internet for a replacement found several places with after market sensors ranging from US$6 - US$25. :)
But because I wasn't buying anything else at this time I thought I would buy from the local VAG dealer, so tracked down the engine model, chassis number and anything else that is needed when buying VAG parts, the quote was for NZ$95 including a rubber 'O' ring which is not part of the sensor but required :o
Not happy with this sort of ridiculous mark up from the stealership  >:( I called the guys at Qualitat, who found the aftermarket sensor without the need of engine code, chassis number and had the stock item for NZ$55 including the 'O' ring. :laugh:
Bought on Friday installed in under 5 minutes, problem solved....... ;D
'03 Passat Wagon V6 4Motion
'74 Fiat 124 Sport series III - under restoration
'74 Fiat 132S - completed restoration
Scooters - '68 Vespa 50S, '68 Vespa 90SS, '86 Vespa PX125
