V6 Cam locking bar
Started by hartster, May 07, 2007, 03:13:18 PM
hartster
Does anyone have one of these, for the 2.8 V6 (AAH) motor. I'm guessing that the 2.6 V6 uses the same tool. It connects to the two cam sprockets to correctly position the cams fitting timing belt, or in my case replacing cam seals.
Need one urgently to be 100% sure of timing after head work, otherwise have to rely on marks.
There's no key on the camshaft to lock the sprocket in place, so no failsafe way of keeping the sprocket in postion w.r.t. the camshaft. I've got mine marked up but still would prefer the VAG tool.
DennyDude
hey man i need the same thing because i need to replace my valve stemseals and timming belt!!!! did you manage to find one?
let me know if you can??
cheers
Charles
typ53
#2
Yep, I've got one as well as the TDC locking pin.  Where are you based?
The Fleet:
Orange Roughy:'90 16v Corrado
'89 Carrera 4.
'12 330d Touring
mark2 golf
is this for the a4 a6 and passat v6s if so just make your own make before you pull the belt of we do heaps of these and work and we don't have a tool.
89 mk2 1.8t
97 mk3 gti 1.8t
90 190e 2.6
17 Amarok v6
09 golf gti
Nice to use the tool though and nice to make use of a friendly Vask offer.
I can vouch for hartster  returning it un harmed and hes in Auckland.
Havent meet dennydude but hes pmed me, seems a nice young fella.
we made up a tool as well tho with a bar and some bolts and a welder.
