020 Gearbox Question......
Started by dubstar, June 25, 2007, 03:14:51 PM
dubstar
johnp was going to do a teardown of my gearbox, but he has talked me out of it as there are no apparent noises and there's no MAJOR leaks.
However there is a minor oil leak and I believe it is coming from the drivers side driveshaft flange.  Mine has a funny green metal sleeve which is slightly dented.  Can I replace this seperately?  Is it an easy pull out and then push back in?
Part number? Price?
It's the part circled below:
You tell us Dubstar ;D I like that picture of all the bits to reco a box.
dubstar
It sounds like the green seal sleeve is quite a common cause of leaks.  Here is one such post I found:
http://forums.vwvortex.com/zerothread?id=2060361
I believe the part number is 020301192A, but I will check with Neil.
And, yes, it just taps into the trans.
Wow, I answered my own question.
johnp
[/quote]
See it's not that hard! ;D ;D
