Author Topic: stereo system in a 1999 v6 Syncro stationwagon  (Read 3855 times)
chocolatelustboy
« on: April 18, 2005, 04:42:49 pm »
Have just bought this car and the stereo appears to be faulty: it has a Minidisc head unit and basically you can turn it on and listen to radio or pop in a minidisc and it will play that fine. However, regardless of whether you're listening to radio or minidisc - the buttons don't work - you can't change the bass, treble, skip tracks, hunt for other stations, change station etc.,... It did come right of its own accord one day (about 1 1/2 weeks ago) but only for about 1 day and then there was a beep noise and it returned to normal non-functionality.
I've noticed that you also seem to need to press the power button twice before it will come on.
I don't really want to replace the unit with a different head-unit - it's nice to have all the lights in the cockpit the same (i.e. red and blue).
Anybody know of the potential problem (and solution) / possible source of a replacement / someone who might be able to fix this thing? Also wonder if anybody knows how to remove this head unit so that I can check for any loose connections etc.,...
Cheers.
tempq18t
Re: stereo system in a 1999 v6 Syncro stationwagon
« Reply #1 on: April 18, 2005, 04:49:09 pm »
Is it a factory unit ?
chocolatelustboy
« Reply #2 on: April 18, 2005, 05:48:25 pm »
Yep - has the VW logo on the unit and I've seen it in another car that I was test-driving. Spoke with Giltrap and the guy was clueless and suspected that it might have been something specific to the Asian market? But all of the lettering is in English so that doesn't seem right?
tempq18t
« Reply #3 on: April 19, 2005, 08:06:04 am »
Oddly enough lots of stereo's in ex japan cars have english writing on them - go figure.
Is the face removable ?
Sometimes with removable face ones particularly in cars that don't get cleaned too often the dust clogs the terminals where the face connects and causes the issues you mentioned. Best thing to clean it is white spirits.
If not then sorry
tempq18t
« Reply #4 on: April 19, 2005, 08:07:24 am »
Quote
I wasn't trying to say you didn't clean your car, I was finger pointing at previous overseas owners
Offline dubstar
« Reply #5 on: April 19, 2005, 08:46:24 am »
You could go to a wreckers and get a stereo from a NZ new passat.  That way you'll have a working stereo with the same colour lights.  Although it may pay to find out if you need a special coded  unit first.
dimistyle
« Reply #6 on: April 19, 2005, 12:08:18 pm »
Hey chocolatefish , It will probably be a SONY that looks like the factory BLUAPUNKT.
Attach a photo if you can or a part number, If its the same as the one I pulled from my 1999 Passat, you can have mine its just sitting in a box in my garage.
You will need a band expander for the NZ radio stations and antenna injector to power up the roof mounted antenna, and keeps the original dash look.
I replaced my stereo with a Panasonic blue and red buttons, but no illumination control. works well and looks great.
PM me for contact details
tempq18t
« Reply #7 on: April 19, 2005, 12:12:33 pm »
Dimistyle, has the stereo got no illumination control or have you not hooked it up ?, Just being nosy cos I like mucking around with installations so it could be something for me to read up on.
chocolatelustboy
« Reply #8 on: April 19, 2005, 12:57:04 pm »
Wow! Thanks for all the response people - I'll check and send photos later this evening.
dimistyle
« Reply #9 on: April 19, 2005, 02:29:24 pm »
Mike, I ended up buying a Panasonic CD player with a changer, I should have bought the  next model up that also played Windows Media. Also it does not have audio mute when the mobile rings, so had to hook a relay to switch the unit off when the mobiles in use. :(
And no it does not have a illumination control wire, so I couldn't hook it up. >:(
I was going to open her up to look for control point for the lighting, but I got lazy.... :o
chocolatelustboy
« Reply #10 on: April 19, 2005, 03:07:02 pm »
Hey dimistyle - how did you remove your original unit? last car was an Isuzu Bighorn - no clever European engineering there - just big ol' screws holding the dash in place!
tempq18t
« Reply #11 on: April 19, 2005, 03:07:25 pm »
It is odd how they don't seem to take your best interests into mind when designing these things eh.
Is the mobile relay running off a car-kit ?
dimistyle
« Reply #12 on: April 19, 2005, 05:31:01 pm »
Yes, carkit mute wire is connected to the relay, other connection is stereo power, all hidden behind the dash. :D
My relay is pretty noisey, so try find a well insulated one or cover it well with foam etc to reduce the relay clicking... :o
chocolatelustboy
« Reply #13 on: April 19, 2005, 11:57:23 pm »
hi dimistyle - here's the minidisc player from the car - is this the same as the one you removed from your car?
[attachment deleted by admin]
dimistyle
« Reply #14 on: April 20, 2005, 10:10:15 am »
See my PM.
Yes, the same unit.. ;D
« Reply #15 on: April 20, 2005, 11:23:05 am »
Al the jap import Mk4 GTIs Ive seen with standard radios in it are like that. Even one of the girls at work here has that same radio in her Mk4.
chocolatelustboy
« Reply #16 on: April 26, 2005, 06:41:27 pm »
Swapped the unit out today with Dimistyle. Thanks to Dimistyle for his generousity and wads of helpful information. Really nice guy and very helpful.
 :D
Offline dubstar
« Reply #17 on: April 27, 2005, 10:15:34 am »
Did it work?  No coding problems?
dimistyle
« Reply #18 on: April 27, 2005, 05:30:08 pm »
No coding problems what so ever as the head unit does not have a security pin, straight swap plus connect the band expander cable that must have fallen off. :o
I suspect the V1 radar detector install disturbed the cabling. :o
We will see if the unit continues to work as its supposed to, may need to power the active antenna to get better reception, but chocolatelustboy is happy for now. 8)
Great lookin' Passat David, black with an aftermarket front bumper and 17" ROH's and tints 8)
« Last Edit: April 27, 2005, 05:32:17 pm by dimistyle »
chocolatelustboy
« Reply #19 on: April 27, 2005, 06:51:49 pm »
Chocolatelustboy is very happy just now - it's the simple pleasures in life... like being able to change radio station or tracks on the minidisk!
Posting my next question... ::)
