Passat Cable Change Box at Pickapart Mangere
Started by robh, October 11, 2007, 03:28:11 PM
robh
Just spent the morning pulling a cable change box off a Passat at Mangere only to find the bellhousing and diff casing is cracked big time!
Not the easiest of jobs to do in pickapart :(
I have the full pedal cluster for converting a mark 2 to a hydo clutch setup on the cable change boxes, including the slave and master cylinders.
Did any of you guys grab the shifter and shift cables out of it early this week?  I couldn't get them out on Sat and went back today to grab them but too late!  I was keen to get the full shifter, cables, pedal box, cylinders, etc so someone could do an easy upgrade to a cable change box.  Also I wanted to take the shifter to an engineering shop to see if they could make something up in alloy without plastic bushes a bit like the VW Motorsport shifter.  If anyone has it and doesn't need it straight away can you let me know if I can borrow it or buy it off you?
