Author Topic: Haldex Traction Upgrade, Opinions?  (Read 2640 times)
eddyg
« on: April 22, 2005, 05:40:26 pm »
What do you guys reckon about this? I was just thinking that I wish my S3 were a bit more taily.
BTW> The KW coilovers have really helped the handling. I think it is the stiffer springs that have helped the most. I'm running 50% on the rear, 25% on the front on the rebound.
Quote
Haldex Traction & Harding European Pty Ltd (APR Australia) have signed an exclusive agreement to distribute Haldex Performance parts through out Australia, New Zealand, and South East Asia. We are a development partner with Haldex & will offer support, service & warranty to all of their performance parts.
The Haldex Performance module will fit all Haldex equipped VW, Audi, Seat & Skoda, including:
- Audi A3 / S3 Quattro
- Audi TT Quattro
- Seat Leon 4
- Seat Alhambra
- Skoda Octavia 4x4
- VW Golf R32
- VW Bora AWD
- VW Sharan AWD
- VW Beetle RSi
We will be doing an introductory offer on the purchase of our first 25 units for $1299 including GST (normal recommended retail is $1599) - This will be available off the shelf, and through your state APR dealer. To qualify for the offer, please contact myself or your local APR dealer.
Technical details:
PreX is a newly developed system which broadens the product range of the Traction Systems division and complements the existing AWD system.
Here is an example of where the performance tuned Haldex Performance Part excels. In the graph below you will see that torque transfer to the rear wheels during acceleration is much more aggressive with the new ECU installed. Increased torque transfer to the rear wheels during acceleration provides more consistent vehicle performance, as well as more neutral handling characteristics. In addition, the Haldex ECU monitors throttle input and transfers torque more quickly to the rear wheels when driving aggressively. In fact, how quickly the torque is transferred is a direct function of how fast the driver pushes the throttle pedal – The Haldex unit will actually anticipate and prepares for torque transfer before actual torque is delivered from the engine to the driveline. Lastly, all safety features will continue to function. For example, during ABS assisted braking or ESP intervention, the Haldex unit will smartly stop transferring torque to the rear to avoid any interference with the vehicle’s OE safety systems.
Haldex Integration:
All OEM security systems are retained and work as originally designed. The ABS braking system or engagement of the ESP is not disturbed with the upgraded Haldex system. Economy at highway cruise conditions is retained by still enabling the transfer of primary power to the front wheels when cruising.
The HPP kit comes complete with the plugs (two) that fit right into the OEM connectors, replacement bolts and a gasket for a simple clean installation. No additional fluid is required. Completely Plug -N- Play.
Why would you upgrade?
The new Haldex Performance Controller is a total replacement of the mechanical and electronic controller that directly affects how the RWD portion of the AWD system works and how aggressively it reacts under acceleration, cornering and braking.
The Primary Control Valve Assembly:
This new performance upgrade is a full aluminum assembly with the latest Haldex performance ECU software, and features an upgraded Primary Valve controller.
This upgrade increases torque transmission at acceleration providing consistent performance with increased over-steer. The torque-transmission is influenced by how fast you press the accelerator down. The Haldex system can transmit torque before the engine delivers torque. At greater speeds the torque will decrease enabling less over-steer and safer driving properties.
The advantages of this HPP upgrade are it’s ability to predict the onset of torque much like the PreX which is for their newer hardware but even more aggressively. This upgrade takes into account the TPS signal more so than the oem software and therefore can proactively begin applying power to the rwd clutch packs before wheel spin begins. As power is increased, more power lock occurs in the rwd unit until full lock is achieved. To summarize, the new HPP is more aggressive with how it transfers power and does so much more proactively than the oem system. This is ideal for autocross, road racing, and street driving as well as enhancements to poor weather driving.
R32 Simon
Re: Haldex Traction Upgrade, Opinions?
« Reply #1 on: May 12, 2005, 01:51:41 pm »
I was going to get that upgrade on my R32, thinking about getting it now for the S3, it would be good to talk to somebody who has had the upgrade done.
eddyg
« Reply #2 on: June 01, 2005, 01:43:18 am »
Hi Simon,
I ordered and had mine put in the post today from Oz. Will let you know my thoughts once installed. There are a few threads on ozaudi about it if you are interested:
http://www.ozaudi.com/nuke/modules.php?name=Forums&file=viewtopic&t=4202
http://www.ozaudi.com/nuke/modules.php?name=Forums&file=viewtopic&t=4258
http://www.ozaudi.com/nuke/modules.php?name=Forums&file=viewtopic&t=4207
Everyone appears quite happy so far. Not sure it's worth the money yet - I hope it is. I'm not a huge fan of the wet weather understear, I'm hoping it'll clear that up a bit (or I could just slow down.. nahhh :-)
Cheers, Ed.
