Yowsa, Ouch and Is there a plan B.....
Started by John Stone, November 29, 2007, 08:29:19 PM
John Stone
Got a reply from the JE agent in California today..........
John,
I am familiar with the early cars and engines. 79.5mm bore x 86.4mm stroke.
We do not have enough info in the system to make these without a sample. We have a particular customer that has purchased pistons for these engines but they were custom from a sample with many changes.
So, If you get us an original sample piston we can make these for you any way you want.
A Basic No Options set of 5 custom Audi WR JE 2618 Alloy forged pistons with wrist pins and JE Rings is $795 per set and takes approx 4-5 weeks to build. Any bore size or compression ratio you want...
Options: Items with * are recommended for Turbo, NOS, and High RPM Normally aspirated Endurance Racing use. See this page for description: http://www.racetep.com/jecustom.html#custopt
*Add $20 per piston for Total-Seal Gapless 2nd rings
*Add $35 per piston for Total-Seal Gapless Top rings (Extreme Turbo and NOS Use.)
*Add $40 per piston for High Heat Ceramic Coated crowns and Moly coated skirts
*Add $15 Per piston for Lightweight or Heavy Duty Wrist Pins
Add $22 Per piston for extreme lightening (Normally aspirated High RPM use only. Not for turbo or NOS)
Add $15 per piston for FSR Forgings. (Limited to certain bore sizes and applications only.)
Add $18 Per piston for Lateral Gas Ports (For Drag Race and High Compression enignes, also good for NOS use.)
*Add $8 per piston for Contact Reduction Grooves
Add $6 per piston for Accumulator grooves
Shipping is $89 by Global Express Mail (Tracked ) to NZ (5 Pistons + your sample returned)
It makes an ABY conversion appealing don't you think?
John
86 WR
04 A3
05 V50T5
5-pot
Eek.  The hairs on the back of my neck just stood up on end.
I need more money...  :P
- 1990 Coupe quattro - R.I.P.
- 2005 Golf 2.0 TDI
So whats happened to your engine then John?
wilco
John,
ABZ ABZ ABZ ABZ.... ;D ;D Only one sound better than a 5.!
qta4
John ,you should ring Ron and see what specs he used, JE still have his specs.
His custom made pistons were $1500 NZ for set landed here
slayer00
John Stone
Quote from: Golfboy666GTI on November 29, 2007, 08:54:53 PM
Until the head comes off, I'm not sure whether it will need new pistons or not, just doing a bit of forward planning in case I need to go down that route.
The head will be replaced with one I picked up from Jem, having some work done on that at the moment. Valves are all good, hardness, vacuum and pressure tests were all good, exhaust guides to be replaced and some work on an exhaust port and helicoils into the exhaust stud threads will make it like new :)Waiting on a pile of parts form Quattrocorner in the UK and then do the strip down.
Quote from: qta4 on November 30, 2007, 08:29:30 AM
I'll be giving him a call.....
Quote from: LOW-90 on November 30, 2007, 07:11:53 PM
Aby head on a 2.5l eurovan block >:D
Has that ever been done? I imagine you would still be looking for forged pistons though >:(
John
86 WR
04 A3
05 V50T5
How about an up date john I hear things arnt so good in the head i sold you land sadly :-[
John Stone
Errr, well yes Jem, I still haven't gone to the engine builders and had a look. I'm guessing they are correct about the cracks, although a second opinion on having it welded may be worthwhile.
I guess I'd better start looking around again for another KG head......
Probably should start a new post and try all our resident 200 owners :'(
I do have one bit of good news though, which will be revealed within a week or so ;D
John
86 WR
04 A3
05 V50T5
Excellent that you have some good news :) Will look forward to hearing it.
John Stone
Quote from: BB on December 29, 2007, 08:55:33 AM
It has the potential to turn the NLA Audi parts issue (and prices) upside down  ;)
John
86 WR
04 A3
05 V50T5
Mike
That's a US name for a VW van with a 2.5 TDI? Not really suited to an engine that you want to rev freely; it's designed for low-down torque. There is a non-TDI crank with a similar capacity but more suited to revs I read about on a UK forum.
mik
Ha, you know i just read this thread and thought that price doesn't sound too bad...
I know theres a place in the UK that makes up sets for 600 pounds...
