Author Topic: Friends Car Needs Help  (Read 2097 times)
Offline AngleBox
« on: February 04, 2008, 04:10:17 pm »
A co-worker needs help with her car. She own's a '99, A3, Auto and Midas has diagnosed the car as having something wrong with the throttle body based on the fault code that came up - 17916.
The car is not idling properly is the only known symptom at this time, but there was talk of checking the high tension leads & plugs, etc. Any help you can offer would be appreciated.
Offline mark2 golf
Re: Friends Car Needs Help
« Reply #1 on: February 04, 2008, 05:05:16 pm »
have they checked the coils and plug these are the most common things to start playing up. and maf will make it idle rough. but i haven't heard or the throttle body. are these electronic or cable.
89 mk2 1.8t
97 mk3 gti 1.8t
02 Allroad tdi
99 s430 merc
90 190e 2.6
uero-jet
« Reply #2 on: February 04, 2008, 11:11:56 pm »
mums mk4 tdi also had a throttle error code come up a few months back.plugged in the scan tool.ended  up it was a broken wire about 10cm from throttle body.
« Reply #3 on: February 05, 2008, 07:53:28 am »
Why doesnt she just take it to a VAG dealership instead of Midas?
Offline AngleBox
« Reply #4 on: February 05, 2008, 08:47:29 am »
The Midas shop charged her $85 + GST for the privilege of scanning her car, so before I advised her heading off to the dealership, getting a better idea of the problem seemed in order.
Offline old4130
  • I Like Bikes too
« Reply #5 on: February 05, 2008, 01:59:08 pm »
Good idea
Or the delership will scan.. readout says this part is faulty, so just replace this part, say its fixed, & charge an absolute fortune, in parts & labour
& probably the car will go back with the same symptoms  >:D
Well in my experience of Dealerships, thats what happens.. even when you say exactly what is wrong, & a good idea of what needs replacing.. after 4 attempts they replace what you said it was, & hey bingo your car is all good again
Maybe I am just getting cynical  ::)
2005 Audi A4 1.8tq S line
1997 VW Golf GTI 16v
2011 Keeway Matrix
« Reply #6 on: February 05, 2008, 08:55:35 pm »
Z-One in Palmerston North scanned my car for nothing when the ABS light came on...
Mk2 Golf VR6
« Reply #7 on: February 05, 2008, 09:53:00 pm »
It will be what euro-jet says, the error codes don't usually lie ::) If its not getting its signal from the throttle body its not getting its signal from the throttle body.
« Reply #8 on: February 06, 2008, 09:13:42 am »
It might just need a throttle body alignment? My Bora came up with a throttle body fault... and the alignment fixed it.
Mk2 Golf VR6
« Reply #9 on: February 06, 2008, 06:41:35 pm »
How do you do that? Dont you just start them and leave them idling for about 15 mins?
Offline qta4
« Reply #10 on: February 06, 2008, 08:13:07 pm »
VAG-COM, read fault codes then delete codes,but save for future ref.
Do throttle body adaption with vag-com.
Run for week and re-check fault codes.
Throttle body errors can be caused by low battery voltage,among other non-fatal things
