Strange request - wheel bolt diameter
Started by reginald, March 29, 2008, 05:50:02 PM
reginald
I need to see if I need to drill out the wheel bolt holes on my new wheels.
I'm after the most extreme diameter on a standard mk2 wheel bolt next time someone has one lying around.
I don't have any with me to messure and I need to get these wheels complete before the car comes back.
The centre bore is fine (60mm).
blackjack
#1
Bolt diameter is 12mm i believe. Chances are they should fit fine. The centre bore on the other hand should be 57.1mm. I had 60mm centre bored wheels on my Golf for a while until i noticed just how wobbly they were  :-\
reginald
yeah is not the  diameter of the bolt but of the lip around the base of the head of the bolt.
Had a probelm on another set of mags where the bolts didn't slot down into the holes thusly didn't allow enough lenght of the bolt to tap into the hub.
