Had a spare couple of hours today to start picking the side off the Vento, It will never be the same again! The C pillar area is going to be a bit tricky to get right first time, some carefull measuring will be needed here to make sure it comes out right. I may just decide on the rear window shape before the qtr panel gets welded on.I decided to leave the roof on for now to stop the whole thing caving in, the roof is supported from the tunnel to the rain gutter area. I also added a brace from left to right and these will be cut out again later. The air saw makes light work of it, the bulk gets cut away and then the spotwelds ground through leaving a nice panel to weld to.
Could you not just 'cut' the factory glass to the shape/size you want?
