GENERAL CATEGORY => Technical Stuff => Topic started by: RGolf on October 18, 2021, 10:27:37 am
Title: Slight vibration noise from rear diff
Post by: RGolf on October 18, 2021, 10:27:37 am
Hi team VASK,
I recently purchased a 2016 Skoda Superb 4WD.
I notice when turning sharp from standstill that there is a slight feeling of very minor vibration or noise coming from the rear of the vehicle.
Anyone know anything about this as an issue? briskoda and a few other forums sound like this is a known issue with the 4WD system across VAG?
Greatly appreciate any thoughts if anyone has an experience or knowledge around this.
Thanks in advance
Title: Re: Slight vibration noise from rear diff
Post by: GLIDN on October 29, 2021, 11:17:55 am
Typically in this instance, if purchased from a dealer, I would notify them of your concerns.
Personally, I would perform a Haldex and rear diff fluid change. Make sure the Haldex filter is done (VW claims there is no replacement filter) Yet I have 3 new ones at home.
Perform the Haldex calibration and test and advise if it continues.
Post by: RGolf on November 16, 2021, 02:39:23 pm
Thanks for the comment
They replaced the fluids and cleaned the filter from what I was told, it is a lot better however still there on at times.
Frustrating…..
Post by: Trofeo on November 18, 2021, 07:31:41 am
Do you notice it more on a smooth concrete surface? Such as an underground Carpark? If so, then it's completely normal.
