Hi,
Do I need certificate if I change the front caliper on my Mk V GTI (single piston) to a R32 one?
Officially yes.
There is very little you can do to your brakes that does not require a cert.
I guess better disc pad and line the way for me to go then.
Thanks for your help
Quote from: McDoof on August 14, 2017, 04:03:54 PM
Officially yes.
I fitted Golf GTI front disks to my 2.0, surely that's OK with OEM parts for the same model
If it's a straight bolt on using unmodified OE parts you don't need a cert.
thanks Phil
Quote from: Filx on August 14, 2017, 07:46:25 PM
Are you sure about that? I remember someone getting grief for putting the Brembo calipers and rotors onto his legacy that were a direct bolt on from the "Tuned by STI" model.
is that because they changed the disc diameter?
Quote from: McDoof on August 15, 2017, 10:30:13 AM
Really, wow - OK. As always I guess the best advice is talk to a certifier first if you have any concerns. I've never had any issues running upgraded OE brakes, calipers and using OE lines and from memory there is nothing in the LVVA guidelines about it, but might be best to check with an authority on it.
Quote from: dummer on August 15, 2017, 12:59:37 PM
Possibly.
He got pulled up about it at WOF time and ended up having to get them certed.
Quote from: Filx on August 15, 2017, 01:27:58 PM
Agreed here. Asking the LVVA guys is probably the best course of action.
who do you use in Auckland area? the three guys I used to go are either retired or no longer in business
A 1A certifier will be able to check what you need, so pretty much anyone on this list
http://www.lvvta.org.nz/documents/suplementary_information/CertifierList-Website.pdf
For Auckland, talk to Clint Field - Near the top of that list, super nice guy and I'm sure he'll appreciate the change from having to deal with flat-peakers and their bodged together Skylines etc.
